Mariner v150 SN: 6455617<br /><br />Assuming this is a 1984 motor - Please correct me if I'm wrong...<br /><br />Motor runs great on muffs, has no upper end under load on water. I've seen many posts on this issue, but few resolutions have been posted...<br /><br />I have not yet checked the compression - I am waiting for my tester to arrive from ebay auction.<br /><br />I also have a flywheel puller, manual, and impeller kit on the way (motor also doesn't pee)<br /><br />Things I have done:<br />1. Squeezed primer bulb while under way - no help<br />2. Checked vent on fuel tank - no help<br />3. Checked voltage to battery while under load - indicates that motor is not charging battery. (does this indicate a bad stator? would this also cause my top end problem?)<br /><br />I have seen many posts suggesting carbeurator rebuilds - how big of a project is this? I have rebuilt car carbeurators with mixed success... Can anyone suggest a good kit with good adjustment instructions?<br /><br />I would like to rule out electrical issues first, as I am more comfortable replacing electrical parts than I am rebuilding fuel delivery.<br /><br />also looking for moral support that this motor IS worth the trouble and time...<br /><br />thanks in advance for any help... I WILL post my progress and final resolution.
