Thanks for the fine reading.. First, when I first got the boat, the red warning light was on. So i found an oil leak on the line going to the small tank on the engine. When I turned the key on after the line was replaced it pumped for a few seconds then blew the top off the tank. I then went to the key and turned it off. Now, the green light barely glows and then blows a fuse under the console. Also the buzzer will not come on. Can the entire pump, gauge assembly be replaced separate?Can I bypass that whole system easily? Thanks for your help.
