Merc 75HP pulls to starboard above 2000rpm
iholmes
I've got a 2001 Merc 75HP on a 16.5ft Ranieri Azzura which has run fine for 2 years. Last service of the engine they took off the prop and alledgedly put same one back on. Now above about 2000rpm if your not holding wheel tight boat swerves violently to starboard i.e. direction of prop rotation. Servicer can't figure it out what's changed. Anyone?
phatmanmike
Re: Merc 75HP pulls to starboard above 2000rpm
check your steering tab, just above the prop. ADjust it the Other direction about 1/2" and try again, see what if does, if not, adjust agaon till u get it<br /><br />m ikey
mellowyellow
aka. trim tab... turn in direction of pull.<br />good luck,<br />M.Y.
