  #1
Old September 19th, 2004, 08:06 PM
Harker Harker is offline
Default 97 Mariner 25hp..fuel pump??
I just rebuilt the carb and fuel pump on my 97 mariner 25hp #OG 490-408, manual start tiller. When I put the pump back together as shown in the Clymer manual with a gasket/pump body/gasket/diaphram...fuel came out of the outside gasket when I pumped the bulb. I took that gasket off and put it back together and it sealed up. Today when I ran it, it started right up but would die in a minute or two unless I pumped the bulb. When it dies, I can hear fuel entering the pump when I squeeze the bulb and the bulb gets hard. Does the outside gasket thickness make that much difference?Do I have the inside and outside gaskets reversed? Another piece of diaphram material came with the kit along with other stuff that weren't shown in the manual..is it the wrong kit? The boat ran like a banshee as long as I pumped the bulb. Thanks for any insight.
  #2
Old September 20th, 2004, 08:33 AM
Trent Trent is offline
Default Re: 97 Mariner 25hp..fuel pump??
You got the gaskets in the correct place?? Number 17 installed correct way??
  #3
Old September 20th, 2004, 09:11 AM
Thanks...this diagram is different than my Clymer manual..mine shows another gasket that goes between the pump body and the diaphram..but it wouldn't work because of passageways not being covered by the outside cover. My kit came with two gaskets..one like #17 and another that had an octagonal opening at the top..I'll take it apart again and see whats what..Thanks again.
  #4
Old September 22nd, 2004, 09:20 PM
Found the problem. The gasket between carb and powerhead didn't have the hole for the pulse lined up..made a hole and it works great now. I never noticed it when putting it on and taking it off 6 or 7 times...heh heh heh
  #5
Old August 22nd, 2008, 09:47 AM
Gpsdependent Gpsdependent is offline
Thumbs up Re: 97 Mariner 25hp..fuel pump??
Good catch....I had the exact same problem only it is on a 1999 Mercury 25 hp. The gasket kit from mercury had only one small hole on the intake gasket that lined up perfectly on the carburator side ....only problem is the gasket need a elongated hole because the "pulse hole" on the intake and the carburator do not line up exactly. Didn't notice it until reading this thread.. Thanks for the help, sure saved me alot of time and hair pulling.
  #6
Old July 29th, 2009, 10:36 PM
JDHNWFL JDHNWFL is offline
I DONT BELIEVE IT!!!!!!!!!!!!!!!!!!!!!!!!!!
I almost added my motor to my reef!!!!!!
Had to add longated hole to carb gasket. Quicksilver is getting a nasty E-Mail!!!!
THANKS!!!!!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 25hp fuel pump problem beaverhound Mercury & Mariner Outboards 4 November 21st, 2008 11:43 PM
'94 Mariner 25HP water pump replacement fish56 Mercury & Mariner Outboards 15 March 25th, 2007 07:37 PM
94 johnson 25hp fuel pump cooperjd Johnson & Evinrude Outboards 3 May 2nd, 2006 10:15 AM
Mariner fuel problem...fuel pump? LubeDude Mercury & Mariner Outboards 3 May 16th, 2005 04:56 PM
electric fuel pump for 1951 25hp evinrude what66 Non-Repair Outboard Discussions 5 July 21st, 2004 12:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
