Re: oil
Outboard engines are characterized by their constant speed, high output operation. They are usually set at a desired high speed and continue at that speed until the destination is reached and then throttled down. Also, they are constantly cooled with fresh, cool, non-recirculated water. Chain saws, on the other hand, are a high action operation. They are constantly started and stopped, used for short periods and frequent overloads are its hard place in life. Additionally they have smaller displacements than outboards and are air-cooled. By understanding how the operation of an engine can affect the oil used and how an oil can affect the engine, we can better appreciate the difference between a water cooled two-cycle oil and one formulated for an air-cooled two-cycle engine.<br /><br />Water-cooled two-cycle engine oils require higher levels of a heavy oil to prevent piston and cylinder wall scuffing. Because of their high average piston temperature, lighter oils evaporate too quickly from the piston cylinder contact area. The heavy base oil, which vaporizes at very high temperatures, resists evaporation and remains in place to provide lubrication to the piston and cylinder. Air-cooled oil formulations must have much lower levels of the heavy base oil than water-cooled engine oils. These oils require only a small amount of heavy oil to pro vide protection against piston scuffing and seizure at peak temperatures. Heavy levels of heavy base oils in an oil formulated for air-cooled engines can cause engines deposits. <br /><br />These deposits form as a result of incomplete burning of the heavy oil. The deposits can cause piston ring sticking and can eventually plug or disrupt the flow of the exhaust system, resulting in power loss and possible engine damage. Detergent additives should not be used in water-cooled two-cycle oil formulations. When burned with the fuel, detergents can produce an ash deposit in the cylinders. This ash deposit can possibly foul spark plugs, form exhaust port deposits which cause loss of power, and possibly create cylinder hot spots that can cause destructive pre-ignition.<br /><br />Now with that said, Use a TC-W 3 or one specified for that use in your outboard!!<br /><br />I recomend a synthetic, as you get better all around performance, cleaner burning, less (almost no) Sparkplug fowling! I have in the past used a 100:1 synthetic oil with great results in an 85 HP Evenrude outboard! I however mixed it at 80:1! I beleive there are even better synthetic TC-W 3 specific synthetic oils now! Racing synthetics should not ever be used in outboards as they do not get hot enough to burn them off completly (unless it is being used for racing or maybe a bass boat that is run at WOT most of the time)!<br /><br />LubeDude
