FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I have a problem with my engine. I can make it go more than 2000 RPM or it will turn off. On idle it is fine. I tried new spark plugs and new gas.<br />If anyone has an idea what I could do to fix the proble please let me know.
Ahoy, Octavio.<br /><br />What have you done to isolate the problem?<br /><br />You most probably have a fuel supply problem, running out of gas.<br /><br />Go to www.outboardrepairs.com and look up your symptoms. Follow the advice there.<br /><br />Come back here and tell us what you did and what you found.<br /><br />Good luck.
