  #1
Old January 1st, 2003, 05:26 PM
stocky stocky is offline
Default no compression 150hpp V6 Mariner
Last time I took the boat out for a spin it overheated. Have just completed a compression test and 5 of the cylinders read >120psi and No. 2 cylinder has Zero. Looks like an expensive fix. Is there a chance of it being a head gasket or being realistic do you think No. 2 cylinder will require either honing, sleaving and new rings. How difficult is pulling down and reassembly of this engine. I have rebuilt car engines in the past so I do have some mechanical knowledge. In addition what sort of money are we looking at to have these jobs done. I'm in Australia so I will just multiply the dollars by 2.
  #2
Old January 1st, 2003, 05:49 PM
Hooty Hooty is offline
Default Re: no compression 150hpp V6 Mariner
Yo Stocky,With zero compression, I think I would pull the head and have a look. It could be several things, from head gasket to severly scored cylinder wall. Removing the head shouldn't be much of a job on that engine. Lettus know what ya find.Best dog I ever had was a Queensland Blueheeler named Belle. She was some dog.c/6Hooty
  #3
Old January 2nd, 2003, 08:43 PM
hondon hondon is offline
Remember, those are torque to yield heads, and the bolts need to be backed off at the same rate that they were torqued on or you run the risk of warpage.Check that spec.I've been burned by this before.
  #4
Old January 5th, 2003, 11:47 AM
G'day Hooty,Just took the head off and its pretty ugly in there. The ring on No. 2 cylinder has snapped and the remnants has chewed the crown of the piston, scored the cylinder wall and the top of the cylinder head is chewed. It looks as though I require at least a replacement piston, rings, either a rebore or sleeving and I hope the circumference of the combustion chamber can be repaired. Sounds like big dollars.
  #5
Old April 29th, 2003, 06:02 AM
mattyc mattyc is offline
I'm kinda late on this reply, but those mid-80's mariner V6s have a BAD tendency... That is, the oil pump is driven by a gear attached to the camshaft. It is a plastic gear with metalized teeth. The gear wears down over time, and all the metal shards from the teeth wind up in your 2 hole and blow you up. You end up needing a new powerhead or a rebore and rebuild.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
80 hp mariner lost compression Boo Mercury & Mariner Outboards 2 May 7th, 2006 05:19 AM
what is the compression for 175 Mariner peterpeter Mercury & Mariner Outboards 2 December 14th, 2004 05:14 AM
Mariner 1985-6 80 hp bad compression rajawolf Mercury & Mariner Outboards 4 December 7th, 2004 10:41 PM
compression on '83 9.9 mariner? buzzroid2001 Mercury & Mariner Outboards 0 July 7th, 2003 11:19 AM
Mariner 2.4L Compression GreginVT Mercury & Mariner Outboards 1 July 29th, 2001 11:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
