I've got a 1989 4.3L/175 HP with the 2-bbl MerCarb carburetor. It's run great until the last couple years. The problem is this - after running the boat for a while (even 15-20 minutes), bringing the throttle back to idle from anything above 1200 rpm causes the carb to flood. Even after the engine floods and quits, fuel can still be seen draining from the venturis. I have removed and cleaned the fuel tank, added an in-line fuel/water seperator, rebuilt the carb (verifying float level and drop), only to have the problem resurface a couple weeks later. The delivered the boat to the marina for diagnosing, and they rebuilt the carb again. After a month of use, same problem. The only thing I haven't done, is replace the carb with a new one, which I am very close to doing. Very frustrating getting towed in or waiting until the engine dries out. <br /><br />Any thoughts/ideas/experiences? Thanks in advance!!
