  #1
Old July 19th, 2002, 09:56 PM
bugsoup bugsoup is offline
Default Frozen lower unit mercury 35 not cooling
I have a 1988 mercury 35hp serial #OB271683. Trying to replace the impellar and the lower unit will not come off. All necessary bolts are loose or off and we have tried to use the hard wood wedges that another forum user had success with. I have even tried to use a tow rope to tug the lower unit off!!They tell me I will have to cut a hole in the mid section of the motor case, then cut the shaft, remove the lower unit and begin the horrendous task of removing the shaft from the crankshaft area.Can I, instead, just cut a hole in the case, then cut the shaft and then use a "sleeve" to connect the shaft back together after I have installed the new impellar?The fish are in!! Please, any ideas will be helpful.The engine runs great, and I hate to junk it. Thanks
  #2
Old July 19th, 2002, 11:28 PM
RandyJ RandyJ is offline
Default Re: Frozen lower unit mercury 35 not cooling
Has the lower unit dropped at all? Since I am not familiar with this engine I can't hope to be totally right.... On the merc's I've worked on I've had to remove the trim tab to get to the bolt which the trim tab hides. It can be a bugger but I've never had difficulty removing a lower unit.. it's just a bittch putting it back on if I have trouble alinging the driveshaft, water tube and shift shaft at the same time.
  #3
Old July 20th, 2002, 02:48 AM
bossee bossee is offline
Hi,When I first removed the lower unit on my outboard(a Suzuki) I first missed the bolt that was hidden under the trim tab and also at first missed the bolt that goes trough the shaft that you control forward/netral/reverse with (bolt was in the other end, up near engine itself). When I had removed them, and all the other visable bolts that held the lower unit, it came off very easy.Maybe it is similar for you?/Bo
  #4
Old July 20th, 2002, 07:14 AM
Thanks for the replies. I have removed all bolts even the one under the trim tab. You are right, the lower unit should land on my foot after removing all bolts, but she is stuck.Corrosion where the shaft enters the "power head" is the likely culprit. Unfortunately, getting to that part of the shaft with penetrating oil or heat is near impossible without creating a whole lot of work and hassle.
  #5
Old July 20th, 2002, 07:21 AM
FreeBeeTony's Avatar
FreeBeeTony FreeBeeTony is offline
What about the shift rod?
__________________
'84 Grady White Offshore
350 Mag w/ Vortec Heads
Alpha 1 Drive
  #6
Old July 20th, 2002, 11:53 AM
FreeBeeTony,Shift Rod?? I was told there is no need to remove or disconnect the shift rod......What can you tell me about it??Thanks
  #7
Old July 20th, 2002, 04:08 PM
I would think something must be disconnected. The shift rod goes from the top of the motor to the bottom. I am just speaking from a logical point of view, I am not familiar with your motor. Sorry. Do you have a manual?
__________________
Alpha 1 Drive
  #8
Old July 20th, 2002, 04:46 PM
FreeBeeTony,Thanks, I don't believe that the shift rod needs to be disconnected. On this particular motor the shift rod is not part of the "drive shaft" that connects to the lower unit.I don't have a manual, but have talked to a few Mercury mechanics up here in Anchorage. I was looking for another answer or perhaps an easier fix.I guess this problem happens on rare occasions and Murphy's Law has it happening to me!Thanks again.
  #9
Old July 20th, 2002, 04:55 PM
Bear Bear is offline
I don't know if this will help. Sometimes it do. http://www.mercruiserparts.com/image...R/16402/33.png Good luck!
  #10
Old July 20th, 2002, 05:02 PM
Another success story. Keep the faith! http://www.iboats.com/cgi-bin/ubb/ul...;f=17;t=006363
  #11
Old July 21st, 2002, 12:19 PM
Bear,Thanks for the encouragement and great link to the answer to my problem.Had it not been for you I probably would have attempted pulling the motor apart with two pickups and a chain!Now I'll relax, be patient, and use a lot of penetrating oil.I'll post my progress...Cheers, Curtis
  #12
Old July 21st, 2002, 12:46 PM
You are welcome Curtis!I'll watch you from here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
frozen lower unit OtisLake Honda & Tohatsu/Nissan Outboards 2 March 19th, 2005 02:05 AM
Frozen 115 yamaha lower unit!!!! rednspeck Yamaha & Suzuki Outboards 13 March 11th, 2005 09:22 PM
lower unit casing still frozen together, what to do Hickox Johnson & Evinrude Outboards 2 June 7th, 2002 02:30 PM
Lower unit parts frozen together ? Hickox Johnson & Evinrude Outboards 2 June 7th, 2002 06:09 AM
Mercury 7.5 lower unit frozen/rusted on? odie Mercury & Mariner Outboards 10 June 7th, 2002 04:10 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
