diggerdan17
- Apr 11, 2003
- 148
took lower unit off, 4 bolts on bottom side and one nut on top side.undid shift linkage under water intake screen.then i could not remove lower unit completely because nut on top part of shift linkage prevented the shift linkage from sliding through the water pump.so i decided to pull the drive shaft right out so i could replace the impellar that way.this was a little awkward but managed to get it in and then i put the lower unit back on and this is where i think i screwed up.i had a very hard time lining up the copper water intake line because i had already put the lower unit on and it is very hard to see up the shaft when this way.is there something i did wrong? ...or do i just have to remove the lower unit again and try and try to get the water pipe inplace?.oh ya...after it was all back together i started engine in barrel of water and i have no water coming through the pee hole .old impellar was alittle worn and definately needed replacing but it still pum,ped water just fine.
