I have a 1978 evinrude 85 hp v4 . i took it out the other day and my throtle cable gave out on me , i knew it was comming lol . but i had to run the throtle from the engine while my son steered . while i was running the throtle manually i had to pull the timming lever forward too. well the motor started spitting and sputtering like it was missfiring . now when i got home i started it and it is doing the same thing . it starts fine and runns great at idle . but if i move the timming lever that connects to the stator . it will sputter and shut off .also it shocks the crap out of you when you touch it while its running . i have taken the flywheel off and taken the stator out cleanned real good and put back .it was touching the flywheel could this be causing my problem . it also shocks me at control box while running . it has never done this befor that day . no goo or greas any where around stator . looks good except where it touched and scraped , but not bad at all.
