FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
im tryin to add a water pressure indicator pipe into the powerhead, i dont know where to drill though. if anybody has an opinion on where to drill please help, thanks.
Re: does anybody know how too add a telltale pipe into a 1968 18hp evinrude?
In my outboard, the telltale comes off the exhaust housing, not the cylinder block or head. See if you can find a similar model in a year that has a telltale and copy the setup. Also, go to johnson website and search the parts diagrams for a model that has the telltale. You can then order the parts if still available. <br /><br />Here is an example of the parts diagrams available at the Johnson site. <br />
mouseboat, The info in this thread may give you some ideas, it deals with the same thing you're looking to do.<br /><br /> http://forums.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=28;t=037675 <br /><br />According to the diagram for your motor, you have a water passage located at the top of the outer exhaust cover, you may need to pull the outer cover to locate the proper place to drill and tap.<br /><br />The BRP site was working today so you can probably locate the diagram for your motor, if its not try the iShopMarine site.
thanks guys, i see what both of your are saying, it looks easier than i originally thought. but if i doo add a telltale pipe, will the exaust get too hot and damage somthing?
