  #1
Old November 3rd, 2005, 04:11 AM
Lief Lief is offline
Default Evinrude 150 Ram Ficht problems
My Evinrude died on the lake a couple of weeks ago. It is a year 2000, and the motor stopped and we let it cooldown, heat light turned on right when it stopped not earlier for some warning. I brought it in and they said the compression was low and a piston was all messed up. Possibly a oil pump problem they said. I thought these motors were fool proof and they would shut down before damage occured. Is there still a warrentee or recall? I'm not sure what to do now, I'm sure if they fix it it will never run the same. Any suggestions?
  #2
Old November 3rd, 2005, 07:18 AM
muskrat muskrat is offline
Default Re: Evinrude 150 Ram Ficht problems
whats the model & serial number i will check to see what updates were done.did the mechanic check the motor for codes.
  #3
Old November 8th, 2005, 07:27 AM
Quote:
Originally posted by muskrat: whats the model & serial number i will check to see what updates were done.did the mechanic check the motor for codes.
Hi, thanks for the help,- The Serial#G04867570 is for a Evinrude 150 Ram Ficht 2000'. The mechanic has not yet checked for codes yet, they are running behind, they have had the boat for 4 weeks.Lief
  #4
Old November 8th, 2005, 08:14 AM
MCM MCM is offline
Was it low or out of oil when it got the piston?As many people have found out, these systems were too new and untested to rely on bells and whistles to tell them when there was a problem.No offense intended here but thats why they've been called idiot lights on autombiles for too many years to remember
  #5
Old November 10th, 2005, 05:14 AM
I was talking about the auto shut off, and there is and always was oil in the tank, I check it every time I take it out
  #6
Old November 19th, 2005, 04:14 AM
KorvetteKapitan KorvetteKapitan is offline
I have a 2001 FichtRam 150 with over 1000 hrs. on it and I often check the oil tank for water content. When tank oil level is low that is good time to empty, and clean the small strainer on the pick up. Never know what you might find in there besides water accumulation.Noticed that BRP Evinrude installs a oil filter now ,inline before the oil lift pump on the newer DI motors.
  #7
Old November 20th, 2005, 03:22 AM
Quote:
Originally posted by lief: My Evinrude died on the lake a couple of weeks ago. It is a year 2000, and the motor stopped and we let it cooldown, heat light turned on right when it stopped not earlier for some warning. I brought it in and they said the compression was low and a piston was all messed up. Possibly a oil pump problem they said. I thought these motors were fool proof and they would shut down before damage occured. Is there still a warrentee or recall? I'm not sure what to do now, I'm sure if they fix it it will never run the same. Any suggestions?
Motor has had no updates & no warranty claim,check with the dealer before put any money into this unit.
  #8
Old November 29th, 2005, 05:14 AM
Thanks for the info Muskrat, I am still waiting for an estimate on the repairs.Lief
  #9
Old November 29th, 2005, 04:37 PM
seahorse5 seahorse5 is offline
Lief,Your FICHT does not have a "shut-down" mode, nor do most other outboard motors.If a FICHT overheats or has a critical "check engine" code, your motor will slow to around 2500rpm, but will not be shut off by the computer.From your description of a "bad piston", chances are the problem was from detonation or an injector that got plugged and ran lean.
  #10
Old November 29th, 2005, 06:07 PM
steamboatwilly steamboatwilly is offline
How could an oil pump burn one cylinder?The oil is injected into the fuel before it goes to the carb.Would it not get all six cylinders?
  #11
Old November 29th, 2005, 08:35 PM
orca orca is offline
James W. The ficht motor oiling system fed oil to each piston individually, so a blocked oil feed line can cause failure of one piston.However I agree with sea horse, more likely an injector or similar.As for fool proof, there were a lot of problems with these early Ficht motors which led to the demise of OMC
  #12
Old November 30th, 2005, 01:14 AM
If it was a blocked oil line, the connecting rod bearing would be either "blued" or "welded" to the crankshaft due to lack of lubrication. If only the piston and cylinder wall was damaged, then it could have been from detonation, hot spot, or lean running.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1998 evinrude ficht problems ronniep22000 Johnson & Evinrude Outboards 3 July 24th, 2004 07:29 PM
2000 Evinrude 175 hp Ficht problems M Hall Johnson & Evinrude Outboards 5 February 12th, 2003 04:56 AM
'99 Evinrude FICHT 175 HP - weird problems! FinestKind Johnson & Evinrude Outboards 3 July 3rd, 2002 04:26 PM
PROBLEMS WITH 200hp FICHT EVINRUDE scruffage1 Johnson & Evinrude Outboards 3 February 15th, 2002 04:07 PM
Evinrude 99 ficht problems, Help! Bill Ferry Johnson & Evinrude Outboards 7 July 22nd, 2001 10:17 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
