Old Coasty
Thread starter- Joined
- Jun 6, 2005
- 17
Model J150GLEIS Faststrike. The motor ran fine, then at 80% throttle it stopped. It wouldn't start. After 15 minutes it started but wouldn't run above 2500 rpm. No warning horn but must have over heated. VRO was low on oil but never lost prime. Good stream of water from indicator. It starts good, idles rough in nuetral. Put in gear, idle goes down a few hundred RPM and dies. I changed the plugs but no better. If you idle at 2000 for a minute, drop back, put gear quickly it will runs ok at speed. Is there something I can try or should it go to the shop.
