Hey there guys this is my first post. <br /><br />I have recently purchased a 1971 Evinrude 40hp electric start engine w/ electric choke. It is sitting on the back of a 14 foot fiberglass runabout. It has a new impellor, is cooling itself properly, starts and idles perfectly, seems to run smoothly when I rev it up. <br /><br />The problem is it should be going alot faster! I cannot even get that little boat to plain. I have had 9.9 hp is the past and this new engine just doesn't seem to get enough RPM to go fast. When I put the throttle all the way down it sounds like it is only at 1/4 or 1/2 power. (doesnt have that high scream that i was used to with my 9.9hp - the 40hp sounds alot lower) I checked the throttle cable and it is tight and when the throttle is all the way down it is pulling the engine throttle to where it should be for full power. <br /><br />I pulled the plugs and both were pretty well new just with some oil on them, one wasnt more oily then the other.<br /><br />Could it be the prop that is not letting me go faster? (the previous owner says it wasnt the original prop) Could it be a fuel or carb problem?<br /><br />I am very good with cars but am still getting used to this boat thing. Any help would be greatly appreciated with this long weekend coming up in a few days.<br /><br />Thanks in Advance!
