Re: Is the new SS prop a waste of my money?
OK, here's the result from the first trials today.<br /><br />I added the Smart Tabs first, then swapped propellers. Went out for a few hours, a little choppy a bit out, but also some almost calm waters further in.<br /> <br />Smart Tabs first; wow! I'll comment on that in a separate thread. Suffice to say here, they did everything they promised to do! <br /> <br />No loss of top speed, but no gain either. The GPS remained at 36 knots at 4300 rpm.<br /> <br />Adding the Ballistic propeller (going from the 23" Black Max alu prop to the 21" steel Ballistic, both 3 blade), gave a noticably better accelleration from zero, a slightly better ability to trim the drive further out at high speeds, and a better grip in the chop and tight turns.<br /><br />However, I also lost 1-2 knots of top speed, maxing out at 34-35 knots at 4500 rpm (which is the highest the engine will go before the rev limiter kicks in), on relatively smooth water.<br /> <br />This should indicate that the original propeller had a slip of 23% (with and without tabs), and the new one a slip of 22%. I had expected a larger difference, i.e. a better bite to show up in the numbers.<br /> <br />All in all, the Smart Tabs were well worth the money, whereas the new propeller is more of a luxury; no great added benefit, but it did directionally help. Since I can't return it, I'll keep it and enjoy the improved hole-shot.<br /> <br />Would I buy the same again? The Smart Tabs, absolutely. The propeller, probably not.<br /><br />Thanks guys, for all your kind and valuable input.
