We have acquired a 1974 115 Evinrude which sat for at least 5 years. The good news is that it runs and idles, it even pumps running in the tank! We are going to put a new water pump on it in any case. The only problem so far is that it doesn't seem to charge. The rectifier tests ok, the ohms on the two yellow wires are within spec for a 6 amp system, and there is approx. 12 volts AC on the two yellow wires from the stator. I don't have a DC clamp on ammeter, but it will read approx. 1 to 3 amps on the AC side with an AC clamp on ammeter. DC voltage at the battery doesn't rise, however. Any ideas?
