1993 115hp 4cyl<br />I replaced my water pump yesterday, my first time on an outboard, and think I may have screwed it up. When I fired the motor up today at the ramp water was leaking out where the shift shaft goes into the lower unit. Here's a pic that shows this.<br /><br />
<br /><br />I also noticed that my water pressure gauge is reading very low, 1 psi at idle and about 4 psi at WOT. I'm not sure what it should be reading as the water pump that was in the motor was old and worn when I bought the boat. The reading I'm getting now is actually a hair better then with the old pump.<br /><br />I think the problem may be that when reinstalling my lower unit I didn't seal off the exhaust chamber properly. I put a bead of silicone on the back of the pump housing but neglected to put a bead on the edge of the chamber like there was before. Here's another pic that shows what I had when I first pulled off my lower unit.<br /><br />
<br /><br />I'm hoping you guys can steer me in the right direction before I pull my lower unit off again. Any suggestions?
