79 Johnson 35hp shift shaft broke
yota08
Hello everyone, I had a problem the other day with my outboard. 79 Johnson 35hp 35el79a. Well it started with a simple impeller change cause no water was pumping and it was overheating. Well I did all that and went to put the lower unit back on the upper and while I had it on I tried to put the shift shaft into the top part where they meet inside the upper unit and while I was trying to pop it into reverse for a better fit, I put some pressure into it and POP!!! Yikes!! So I decided to take the lower unit back off and found that the shift shaft moves up and down freely now. No clicks into forward, neutral, or reverse!?!? I don't know what I done. Has anyone ever took apart one of these lower units? I've looked up videos but can't find a match. So far Im trying to pull out the beating carrier and it ain't coming out! I don't know if it does but most videos I seen they do. So I need to know what I did? How to fix it? And how to take it apart? Please if anyone has before it would be much appreciated for some tips and info. Thanks!
Joe Reeves
On the 1979 35hp model, that lower shift rod is supposed to screw "all" the way in until it's snug.... and you're saying it's loose, that is pulled out of the lower unit? I'm at a loss to understand how that could happen.
oldboat1
Maybe the upper shift rod has broken away from the lever assembly(?) If so, believe the powerhead needs to be removed for access.
yota08
It's screwed all the way in alright but I'm not sure how I did it but I tried to push it down into reverse and I guess it already was and push down to far and broke something? Now it just goes up and down freely.
yota08
Nothing's broken from the upper unit up, it's just all in the lower unit.
oldboat1
What goes up and down freely? The shift lever may not be operating the shift rod.
yota08
What goes up and down freely is the shift rod from the lower unit. I have the lower unit pulled off. Upper unit is fine.
yota08
Can you pull the rod out of the lower unit ??
No I can't, just goes up and down, if I was to unscrew it out yes I could but no it just moves up and down, no clicks into forward, neutral, or reverse.
Did you change the oil ?----Remove any screws from the gearcase ?----Perhaps a screw different looking to the fill / drain screws.
Chinewalker
Only a couple things could have happened - either the pivot screw was removed and not reinstalled correctly, or the horseshoe shaped collar that rides on the clutch dog has broken. Did you remove the pivot screw for any reason? That would be the "lucky" fix, as you may be able to reassemble that without further surgery. If that's not the case, then the unit will have to come apart. There are two bolts recessed into the bearing carrier that need to be removed. Then you'll need a hefty pair of snap ring pliers to remove the retainer ring that holds the retainer plate in place.
yota08
I did not remove the pivot screw, so it could be the horseshoe shaped collar. I tried to remove the bearing carrier but it would not budge? I removed both bolts inside and used a puller and it did not budge!? Am I doing something wrong?
Joe Reeves
It does not take much physical pressure to shift the unit into either gear or neutral... and it clicks in! One must turn the propeller when shifting the engine (not running) or when having the unit on the bench to align the lobes of the gear and shifter dog.
If that shifter rod is screwed in as it should be and you can move it around..... acts like it is attached to nothing.... you have no choice but to dismantle the lower unit. Hopefully you are mechanical inclined and have a factory service manual on hand to coincide with instructions and advice you may obtain here.
oldboat1
I might be just out to lunch on your posts, but keep thinking there may be nothing wrong with the shift mechanism -- might be your expectations of how it works (no offense intended). Manual gear cases are routinely tested by pulling up/pushing down on the lower shift rod, when the l.u. is removed for service. It doesn't take much movement to shift between R/N/F (may need to turn the prop a bit to get the gears to mesh, like Joe R. mentions). On many models, there might not be much of a definitive click -- just slides kind of subtly between gears. Some are spring loaded, and that would give you a different feel or response.
The feeling that something busted may be a connection/reassembly issue with the connector between the upper and lower rod.
yota08
Thanks everybody for the advice, but yeah I'm sure something inside the lower unit is broke but I can't figure out how to take it apart? I can't get the bearing carrier pulled out?? Can't figure it out?
heypawpaw
Did you use snap ringf pliers to remove the retainer ring per chinewalkers post #11
SweetD
This procedure can take some patience with the puller. What worked for me last time was to tension the puller and then lightly tap around the bearing carrier on the outside of the lower unit casting. Let it sit for a bit, tighten puller slightly more, tap, and repeat. The carrier may finally move. If this doesn't do it, you may need to apply some heat to the casting as evenly as possible to expand it, then tighten the puller. Also you should be using penetrating oil like Kroil around the bearing carrier. Patience is a virtue with this procedure!
???---That ring is removed AFTER the stubborn bearing carrier is out !!
