well, well well. I found the problem. Might have been the STUPIDEST thing I have ever done. I switched the fuel in with the pulse line on the VRO so it was pumping gas into the crank bypassing the carbs. I switched this up, hit the lake and it ran good. But when I got passed the idle free zone, I hit a weak point. It was still slugish. I know what a OMC motor sounds like getting on plane, and this didnt sound like it was running right. Now the primer ball was rock hard, no fuel leaks. It took 1 minuate to get on plane at WOT and the motor wasnt screaming like it should have been. I was getting 26MPH and about 4500RPM, no more than that. I fianlly didnt get any surging though, steady RPM. Im guessing it may be the plug wire I put it. When I was on the lake about 3 weeks ago, the cowl broke a plug wire, I replaced it with a 88 9.9 wire to test it, it is shorter and the boots arnt straight on their. Im going to get a new set of plug wires in hope that it will solve this. ANy other tips, could I have a bad coil pack or weak? THANK YOU!
