Whilst I'm doing trailer drudgery, I've started rethinking outboard size again. Found an online speed calculator that you put in hull type, weight, and hp, and the calculator gives you an estimated speed (+/-). That calculator said I should get approx 29 mph with a 14' boat, 800 lbs and 15 hp.
Now, my old boat was 17', 1200 lbs with a 60 hp on and the calculator said it would get 49 mph. In real life it wasn't even close to that, only achieving 30 mph on a good day.
So, anyone have a realistic idea what I can achieve with a 15 or 25 hp on a 14'er at 800 lbs? Is there any way of knowing what it would take to get the boat up on plane?
Thanks much.
