oldboat1
- Apr 3, 2002
- 9,612
I'll guess that on muffs you pressurize the leg when it is full of exhaust water. You might back off the hose pressure and see if the stream slows or stops.
It would be good to let it idle in a barrel and monitor head temps. While the motor may be slow to heat up, once you get it up there keep an eye on it. The main danger running in a barrel is overheating -- exhaust will heat up water in the barrel. It can go from safe temps to overheating pretty quickly -- can minimize danger by running slow and keeping a hose running to top off water. Sink the leg deep (about half way up).
I wouldn't be too quick to pull out the t.stat, as it's a little tricky on the '85 -- try to determine if temp is properly regulated first.
Good luck with it.
Good luck with it.
