l008com
- Jun 14, 2007
- 730
The towing question is not actually Trailblazer specific, but still probably right on topic.
I have two small trailers I tow regularly. A 5x8 utility trailer and a smallish boat. My truck has a 6 pin plug, so I have a 6 pin to 4 pin adapter that I plug in and it works great.
But the trailers both have these cheap flat 4 cables that you can get everywhere. I keep having to replace them because they are all made so cheap. The wire insulation eventually breaks, shortly there after the copper fails. It's always the same deal. And back when I had an S10 which, rather than a heavy duty 6 pin socket, had just another flat 4 connector wire hanging down, the truck end would have the same problem!
I've used different brands but they're all the same. Maybe these connectors are ok if you tow once or twice a year. But if you tow weekly, they're junk.
So my question is, does anyone know of a better system? I know the ultimate solution is that I Could upgrade both trailers to 6 pin heavy duty plugs. But I'd rather find some form of 'heavy duty' or just a quality 4 in plug, so I could maintain compatibility with other vehicles. Any suggestions?
