Tim I never said he should replace his rectifier and only suggested the rectifier would be the likely culprit.
I should add, here is the essence of the thread.
With the 0.5V, 0.1V & missing? 0.4V it seems to me that Mark has already started to isolate the problems but that's only a guess at this point.
Voltmeter, ammeter & even ohmmeter, same = same = same, they all measure current flow.
Vic the voltage readings mean that Mark (OP) has a leakage back to the battery negative.
Any thoughts on what might cause this to occur or what I should check?
