looking for mercruiser wiring diagram, pre thunderbolt
stang32
i have an 88 5.7 with prestolite distributor & need the wiring diagram, all i find are thunderbolts,
thanks
Ayuh,.... That's because they were all T-Bolt ignition by '88,.....
Try manual #1 for earlier stuff,....
achris
More fish than mountain goat
thanks
If it has a points distributor, it ain't '88....
Do you have a voltmeter or an ammeter in the dash? And what colour is the output wire (the big thick one) from the back of the alternator, red/white or orange?
Chris.....
achris
I have found a few drawings that may match what you are looking for. Is this an inboard 'Ski' engine? If it has a Prestolite distibutor, then it will have had points as factory supplied. If it no longer has points, someone has modified it. Can you post the engine serial number to be sure we get you the right one.
Chris......
stang32
the engines have been replaced several times already, so no #'s. the boat is a 30' searay. there does not appear to be any points in this distributor.
achris
The boat could be a 300' searay, doesn't matter. What the boat is is total irrelevant. So, it's an inboard. It there a name on the module in the distributor? Does the plate the module is mounted to move? Any chance of a few pictures?
