tjh79
- Jun 8, 2016
- 6
Ok so i have a 1985 lowe 16' superior v aluminum boat. Transom rated for 40 hp and boat carry capacity is like 975... now i normally wouldnt do this BUT i am stripping boat down installing a sealed sub floor with aluminum diamond plate with sheet foam under floor from bow all the way untill under rear seat (14' subfloor) no water gettin in... then casting deck from front bench (3 total) to bow, middle bench is being widened 10 inches front to back to install multi compartment live well... now good stuff rear transom is getting pulled apart raised 2.5 inches (17.5 now going to 20) reinforced into sides, bottom and tied into rear bench seat... also installing 2 pontsons .65 cf each should add atleast extra 75 lbs capacity to support motor and to top it all off changing from tiller to side console... now will a evinrude 50 hp motor be to much and or be dangerous... now im not goin to be sellin this anytime soon and im NOT a full throttle wide open guy but i do plan on fishing areas with a bit more current.... motor and controls were free so...
