ciscokidd
- Aug 22, 2012
- 145
Mounting bracket on 2 of my window porthole frames that allow the lexan/plexiglass window to be tilted up for airflow have broken. Does anyone have a part number or know where one can source out replacement frames. The windows are secured by 3 swing type mounts, one on each side and one at bottom to keep the window closed. When these are unlatched the window can be lifted up. Apparently the mounting holes on the frame have become fatigued or the bolt was tightened too much at some point and the brackets that the bolt slides through have both broken. I need to replace 2 starboard frames, one in my head and the other in forward vberth area. Anyone know a supplier, vendor or alternate part that fits/works or option to repair
