Giacomo8690
- May 24, 2015
- 51
Hello Iboaters! I was hoping I could get some advice on building a wood floor in my16ft Mirrocraft aluminum boat. Pictures can be seen below. The boat has two benches and has never had a floor installed before. I have 1/2 marine grade plywood which I plan supporting with aluminum angle and aluminum square tubing. I plan on attaching the angle to the ribs (port to starboard) using blind end rivets. So I have all the necessary supplies currently including cardboard to measure floor. I have run into a problem where I am not sure how to measure the floor in my boat so it is level however. I just want to make sure I do this right the first time. If you guys have any recommendations I would greatly appreciate them..
