- Jul 23, 2011
- 47,618
The cam is supposed to be an HP500 clone grind from Arizona Speed Marine. it is a custom Comp Cams grind
Here are the old crane specs for the HP500 EFI.
292*/298* @ .004"
230*/236* @ .050"
.352"/.359" lobe
.598"/.610" valve
114* LSA
109* ICL
119* ECL
Here are the HP500 carb’d cam specs
284*/292* @ .004"
222*/230* @ .050"
.576"/.598" valve
110* LSA
105* ICL
115* ECL
The comp-Cams custom grind version thru AZSM
277*/287* @ .004”
228*/232* @ .050”
.588”/.596” valve lift
114* LSA
110* ICL
VOI 4
VOE 54
VCI 44
VCE -2
I verified the cam when I installed it using a degree wheel, dial indicator and a tubing wrench as a piston stop. I checked cylinder 1 and 3. The actual valve lift I was measuring was .586”(.344”) and 0.594” (0.349”) using checking springs ($3 from ace hardware). cam valve events match the cam card
I measured 3 times prior to buttoning up the timing cover, bolting the heads on for the last time and
Per recommendations of AZM and Comp, the cam is installed straight up.
292*/298* @ .004"
230*/236* @ .050"
.352"/.359" lobe
.598"/.610" valve
114* LSA
109* ICL
119* ECL
284*/292* @ .004"
222*/230* @ .050"
.576"/.598" valve
110* LSA
105* ICL
115* ECL
277*/287* @ .004”
228*/232* @ .050”
114* LSA
110* ICL
VOI 4
VOE 54
VCI 44
VCE -2
