- Jul 23, 2011
- 47,565
FYI - those are very pricey heads for a boat. good old cast iron vortec's my recommendation for a boat, especially for just cruising. plus, unless you have at least a half-system, a waste of money.
Aluminum performance heads (Power Pro) 200 runners, 64cc chamber ...what other info should I ask for?
HT32 what sized Lib did you put that BB in I have two worked Merc 454 I took outa a stinger with like no hrs so that was the first plan to use one of them to repower the boat wit but was talked out of it
Well I just read your thread so now back to my original question from the spring then...what do you think about me putting one of my BB's in the boat seeing that I already have the engines it would be a lot cheaper of a project but can that little boat handle the extra weight of the BB. My Lib would b considerable smaller than yours because of the molded swim platformMine is a 1987 211 Liberator. I reiterated the whole mess in the thread below! Complete with pictures....... I used a Bravo III but yours would probably run pretty nice with a Bravo I ..........As much as I like it, I'm probably going to sell the boat because I want a BIG Formula (with TWIN BBC/Bravo III's ) Cheers, Rick http://forums.iboats.com/forum/engi...utdrives/8581616-another-winterizing-question
from what iv seen from looking around I think you could have ordered that boat with a big block so the stringers that the motor mounts bolt to must be wide enouf to bold that monster in right? Because when I look at the mounting point on the boat their isn't much room and isn't the BB mounting stance wider than the SB?
Haha yea It would be realy cool to built one of those motors and the lil Libby would be soooo frigen FUN!!! But that's not in my cards to do right not ...from what iv seen from looking around I think you could have ordered that boat with a big block so the stringers that the motor mounts bolt to must be wide enouf to bold that monster in right? Because when I look at the mounting point on the boat their isn't much room and isn't the BB mounting stance wider than the SB?
be sure what drive you have before you plan to scrap it,my 89 201 liberator has a 350 dog clutch cobra with 'king cobra'labelling all over it!
