Watermann
- Jan 12, 2013
- 13,753
I guess I have to ask why the deck isn't sitting down on top of the ribs? If there's foam holding it up then it's going to need to be shaved down. Screws will hold by a couple teeth is all, very weak compared to the rivets and they won't suck it down without stripping out. You don't want to have it up either with a gap between the deck and rib because as it settles and it will over time, it will loosen anything you use either screws or rivets.
