Still Need Help - Water Pressure Gauge Not Working Yamaha 2003 115 HP
Status
Not open for further replies.
111torrance111
I have a 2003 Yamaha 115 with a Water Pressure Gauge Problem, had a few replies but haven't found a solution.
1st Test: Check behind the gauge to see if water was getting to the gauge -- No Water
2nd Test: Check at the motor to see if water tube was pinched/leaking -- Niether
3rd Test: Remove fitting and make sure it's clear -- Removed & it's clear
4th Test: Run Motor with plug out -- Still no water coming from the engine block
Motor runs cool & doesn't over heat, the pee tail is strong & the impeller was replaced last year. Gauge was working fine & just stopped.
I see other post with the same problem with no replies, I assume somebody has figured this out already. If so, please share with the group.
This has been a great site for troubleshooting, thanks for any advice or help you may have.
Jerry
schematic
Re: Still Need Help - Water Pressure Gauge Not Working Yamaha 2003 115 HP
just for kicks, check to see if the poppet valve is stuck open... (pressure regulator valve)
111torrance111
Thanks for the suggestion, where/what is a poppet valve?
schematic
part 18 (pressure regulator valve)
111torrance111
Thanks,
I'll take a look, what other function does this valve perform?
schematic
Dumps excess water with increased engine speed, which results in a regulated coolant pressure. This pertains to Yamaha.
Other manufacturers use this valve to increasing coolant flow at high speed.
If this valve is stuck wide open on your engine,(combined with a worn water pump) it could result in very low water pressure....
jds75
Hi did this ever get resolved? I have the same issue on my 2002 115
Status
