JWeislocher
- Mar 20, 2012
- 3
I have a 2002 Merc 50hp 4 stroke that has been alarming at wot. I am under the assumption that it is an overheat alarm. I have replaced the impeller and changed the oil a week ago.
The problem is when running anything over about 1/3 throttle I get an alarm. The alarm doesn't occur immediately but goes off after I have gone about 100-200 yards. If I back off the throttle the alarm goes away. I have not had the alarm occur while idling, but I usually dont leave the motor idling for any long period of time. If I rev the motor with the fast idle lever and leave it idle at higher a rpm I do not get the alarm.
Under the assumption that this is an overheating problem I removed the thermostat and did a boil test. The thermostat did not open and I do plan to change it. But in my thinking, shouldn't the motor overheat at idle as well if the thermostat is not opening?
