timrod
- Apr 19, 2009
- 28
91 3.0 with points dist !!! Engine only has 50+ hrs sense over hauled with every thing, bored and pistons new head new cam and every thing else i could put .This thing will run perfect for 20 to 30 miles @ 3000 rpm till we get there .I can throttle down slowly to idle speed and it will start to cut out just a little on idle and then stop !!! It will not crank for 10 to 15 mins and will start back and run perfect for a short period till it idles again .If you can get started and get it in gear running and above idle it will run perfect, if you dont let rpms down low if you do it will die and you will have to wait !!!! Ok now i will tell you what i have done!! New Manifold and riser ,new dist, new coil ,replaced resistor wire in harness ,then changed to regular wire and went with a built in resistor.New wires new plugs ,timing is set to book specs .When it does this i can take off plug wire at a plug and it has a blue spark at least a inch ,take off flame arrestor and pump gas and it has two streams from accelerator pump .That is gas and air and spark .So tell me is this dam thing vapor locking in the intake when it is getting hot ???? Oh and i forgot the water temp is 160 degree and cool enough i can take the cap off with no pressure !!
__________________
__________________
