kellmike626
- Sep 19, 2009
- 104
Hi guys. This forum has helped me to get to know my engine quite well. I hope you guys can help me out.
So, to start off, I have a 2005 Bayliner 175, equipped with an 05 3.0L Mercruiser Engine and Alpha I Gen II Outdrive. I am the second owner, and well, the first owner (4 years) didn't do much to it, as in the didn't keep up with some of the maintenance. For winterization he just drained the water from the engine.
Engine runs pretty much flawlessly. Shifts fine from Forward-Neutral-Reverse, planes with no problem, and I can top out at W.O.T with no issues whatsoever. No leaks anywhere, everything is fine, at least I think..
Keep in mind, I've only had this boat since last September. I did winterize it correctly.
Now, ever since the season started, I've been getting this noise (almost sounds like a ticking sound, but not that experienced with engines so I have no idea how to describe it). This sound only comes between 650-2000 RPMs, after that it's disappeared, and when going back to idle, it sometimes disappears for the rest of the time.
Sometimes the noise doesn't even come at all..
I have provided a video (it's mainly just the camcorder sitting there beside the engine, but the sound is clearly noticeable. Coming from the port side, near the top of the engine. I give a quick glimpse of the gauges at the end)
http://www.youtube.com/watch?v=UUtzLsWf-b8
Now, am I just being paranoid? Or is this going to become a problem? I know 3 litre engines aren't meant to be quiet, but this is frustrating me as the sound gets annoying sometimes.
Thanks for any input
