Re: Restoring Pattern on Gelcoat Deck
I've done a fair amount of glass mold making, theres a special resin for the surface of the mold, the stuff I used is orange colored and is best sprayed on, but I've brushed it. Its poly.
Like you said, wax the plug part first, real heavy and polish 4 times, leave the final wax unpolished, spray a coat of polyvinyl and let dry. Spray the orange mold surface on (it stays tacky) and lay a light cloth (3/4 oz) if you want details to show in the mold. Then a couple layers of 2 oz weave with clear mold making resin, the molding resin doesn't go completely hard so it doesn't require sanding, then matting. I like 3 layers of matting for a decent temporary mold. Finish with a layer of finishing resin which will go hard and harden all layers beneath it.
Pop it off and start polishing, waxing 4 times before use., maguires machine polish can be used if you want very fine details.
I spraypaint the inside of the mold first , then layup glass on the paint before paint goes completely hard, it works real neat and comes out pre-painted.
Certain shaped molds need wooden reinforcements to prevent buckling.
