I'm in the process of rewiring the trailer, with LED tail and marker lights.
The "kit" came with wire nuts, which I assume is for the tails and the pinch type conncector to splice in the markers.
Are these the best connectors to use, or just the cheapest? This trailer will set outside plenty, be dunked in fresh water only. I'd like to use the best holding connectors and to protect them from corrosion, as best as possible.
I normally use the tube-style connectors, that you crimp each end, which contains a wire.
Any input appreciated.
