My boat engine has been intermittently missing at speeds from cruising to full throttle for 4 years. I only put about 5 hours runtime per year. The missing is audible but the boat doesn?t stall or bog down. I am looking for any suggestions on what to try to fix this.
The motor is a 1973 inboard OMC 250 hp (350 ci with Rochester Quadrajet and Mallory flat cap ignition). It does not have a water separator on it. So far I have changed the points and condenser, checked the timing, added dry gas, and changed the fuel filters in the carburetor and inline. The problem seemed to go away for most of a summer when I changed the points but it came back.
What should my next step be?
Change the distributor cap?
Change the coil?
Change the spark plugs?
Change the spark plug wires?
Add a water separator?
Check for a wiring issue?
Other suggestions?
The boat is on a local pond and I don?t have a trailer. There are a few mechanics that make house calls but this could get costly if they don?t fix the right thing first. I would like to try the easier stuff myself. Thanks!
Change the coil?
Other suggestions?
