oonighttrain
- Jan 21, 2008
- 50
as you may know from my previous posts.. i have a 1998 yamaha 50 horse 4 stroke..
it had low compression on #1 and #4 of the 4 cylinders.. so, i took the head off, took it to the machine shop, they did a vacuum test on all the ports and told me it was fine..
i got some info froma few guys on here that said to do a leak down test..
so, i did, had air coming out of the dipstick tube when i put air in the #1 cylinder..
so, my bud and i took the powerhead out, took it all apart, honed the cylinders and put new rings in....
after hours and hours of work.. the motor is back together.. it runs....
BUT, i still have the same issue.. runs a bit rough and still have the same compression problems..
btw, i miked the cylinders and they all were within specs...
2 and 3 had over 120 p.s.i. at first.. and still do...
the weird thing is, im getting erratic compression readings on #1.. it will show almost no compression, then it will read 30, then 60... ive tried 3 different guages.. pretty much all the same...
MY BRAIN IS FRIED FROM TRYING TO FIGURE THIS OUT!!!!!!
