Re: 2003 Yamaha 150
A little more info is needed.
A model # is always the best way to let others know what motor is being discussed.
What does motor breaks down mean?
You can always start with compression and spark on all cylinders for basic info. Then timing. A timing light on the different plug wires may show if you are loosing spark at problem RPM.
Check fuel pressure/vacuum with a gauge to see if there is a fuel delivery problem.
http://forums.iboats.com/showthread.php?t=283363
You can use a DVA adapter and DVM to check CDI outputs and inputs for troubleshooting spark problems
Carb problems is still my guess without any more info.
