If it doesn't smell like gas don't use it in anything.Weve got about 50 gallons of old gas and we dont have a clue what to do with it. It looks about like urine when you put it in a bottle and smells nothing like gas. Im not even sure if its ok to put 5 gallons in our cars/other boats and run it with 15 gallons of good gas. Its at least 2 years old.. Maybe 3..
+1 vote for using it in lawn equipment. I think my lawnmower would burn rocks if I got them into the tank!Lawn mowers and Gardner tillers love the old gas. The 2cycle oil helps lubricate the cylinders and while your cutting the grass or tilling the gardner.
cajuncook1
You could wear a BP uniform and then just go dump it into the nearest lake...lol just jokin
eavega said:I think my lawnmower would burn rocks if I got them into the tank!
Lawn mowers and Gardner tillers love the old gas. The 2cycle oil helps lubricate the cylinders and while your cutting the grass or tilling the gardner. You can have the memories of days on the water with the smell of combustion of the 2 cycle mix fuel!!!
cajuncook1
Nobody said anything about the gas being mixed with oil....just that it was old.
Small air cooled engines are often better run with higher octane gas because it burns cooler.
Old gas and small engines can be a problem.
Better to run it in larger, water cooled stuff. Full sized tractors, pickups etc..
