Hi guys, having a little trouble initially starting my Evinrude 90hp v4 1891 model. I'll run through my starting proceedure as I was told to start it, maybe I havn't quite got the knack. First of all, prime the fuel then turn over with choke but no gas until she fires, which is usually after 3 or4 turns then apply some gas and turn over without choke. She usually starts and runs for 3 or 4 seconds but then dies. This is the bit I get alittle stuck, if I apply gas she just turns over without firing but if I turn over without gas she fires and disengages the starter imediately but doesn't start. I've tried a mixture or applying a little more choke and throttle but usually end up flooding the engine and flattening the battery. When I do get her running, there's lots of smoke (I'm guessing unburnt fuel) for a few seconds but the runs like a dream. Starts first turn of the key no throttle all day long, no missfires or flatspots.
Just to give you a little history of the engine, she has just been serviced, carbs cleaned, new plugs etc. Previous to me purchasing the engine it hadn't been run for 2 years. Thanks guys
