Xesvuli420
- Sep 20, 2009
- 144
Never seen anything like this before, but bet one of you guys has a good idea what it is, here's the dilly o...
If I'm sitting still, and idling, the boat stays at the cool end of the gauge, if I creep forward (as fast as I want to go BEFORE the boat tries to start getting on plain) the temp stays cool for as long as I want.
(however, as a side note, the day I un-winterized it, it was idling with muffs on, and it was overheating)
Once I get on plain, even at the slowest speed required to stay on plain, the boats temp climbs. Even at full speed the boat temp will climb (at the same rate as minimum plain speed). It will go all the way to the hot end of the gauge (the dash before the 240). It may have went further, but I backed of the throttle and allowed it to cool.
Here's the weird part (for my understanding at least)..
No matter what temp it is, If I come to a slow speed, or stop, then WOT, the temp drops all the way back down to the cool end of the gauge for a moment, then starts climbing again. For example...
If I'm running a little hot, say 200, and I slow down for a brief second, then WOT, the boat will start to cool all the way down to say 140. Then it will stay there for about 10 seconds, and begin to start climbing again back to 200 Plus
I can even be right before 240, slow down, and then WOT, and it will cool it back down to around 190 for a second, then go back up again.
I'm not sure that If I left it at WOT it would ever go above the dash mark before 240, BUT i'm not willing to take that chance. In the past season, the boat hardly ever went near 200. HOWEVER, it does seem to slow down the rate of which it is heating once it gets higher. Its almost as if it wants to stay around the 8 or 9 mark. Those are the 2 marks right before 240. Im not sure exactly what temp they represent, but its more than 210.
Anyone have any ideas?
Thank you
Thank you
