Re: 87 Sea Ray Seville Restore
March 14 2010 update.
I had great weather this weekend and we started rebuilding the bow area. So far we got the wood basically cut and shaped and dry fitted. This weeks pics sow he dry fit for the bow. The forward area that has not been fitted yet is going to be a wider deck than the original. It is to be a fishing deck so it needs a larger area for standing on. the floor which originally was glassed to the sides will be a lift out floor. I thought the original ski locker was good but I would like to be able to access the entire area. So the plan is that the forward floor that you see in the pics would be framed in by using aluminum angle pieces attached to the side boards and supporting the floor. A bolt system would be used through these angle to secure the floor. That way it's locked down for use and easily removed for service (drying) or other reasons. I think it will actually make the forward locker bigger.
The fiitting of the wood at the curved areas on the deck services was simple with the aid of making a template out of a large print stock I had on hand. I knew these old building plans I keep would one day be usefull LOL.
The internal pieces that fit up to the hull line inside the original lockers was a bit tricky. Lots of measurements, lot more measurements, a little cutting, then recutting, then do it again 3 more times. Oh what fun.
Now we are ready to start the Glassing. I don't think the temp. was warm enough yet. It was 75 for a bit but I think since I am working outside that I need 70 deg. to be more constant to ensure the cure of the resin.
That's it for now will update as we go. The building instead of destructing, gets my hopes up and I think I might make my deadline to be on the water the 1st weekend in April. It's been a lot of work so far but very enjoyable. I love building things.
http://i885.photobucket.com/albums/...ville 3-6-2010/Sea Ray 3-14-2010/IMG_2771.jpg
http://i885.photobucket.com/albums/...ville 3-6-2010/Sea Ray 3-14-2010/IMG_2770.jpg
http://i885.photobucket.com/albums/...ville 3-6-2010/Sea Ray 3-14-2010/IMG_2769.jpg
LR Custom
http://forums.iboats.com/showthread.php?t=376954
87 Sea Ray Retore
