Ayuh,.... I'd Fix it,+ turn the Key.......
Put a tyre around the prop and tow it with the leg lowered and the motor fully turned to starboard. Fix up a gravity feed waterline from a garbage bin to the muffs. Get tow vehicle up to speed and then ignition on, dump her into forward. Once started, select neutral and leg up. Let her warm up, tyre off and then and back her into the ramp.
PS: Practice first on someone else's!
