I obtained a twin to my 53 Sea King 5 hp this weekend. To make a long story short, I had complete working powerhead from a 51 Sea Bee 5hp on hand which was what was wrong with this one. Swapped out the power heads and now I have a partially functioning outboard. Only runs as long as it takes for a bowl of fuel to get through it. What a gas hog !! I have the tank soaking with kerosene at the moment.
Sign 1) Well as you may have guessed, no water pumping. Took the lower unit off (I am really good at this now from the other one). Turns out the water pump including all the intakes were packed/encased in a mud and grease mixture that smelled like a swamp or storm drain. This was good and bad. In a weird way, I think it preserved the impellor. I took it out and the blades just about sprung out straight.
Sign 2) I started tearing into the old powerhead and found that it is rusted solid with no chance of revival.
Question? I also found out how well that red sealant (reminds me of red locktite) holds. Is there any trick to separating parts joined with this stuff? MEK thinner or something?
Sign 3) The ignition system was also encased in mud.
Sign 4) When I first got it home I had to power wash a layer of grit off of it.
What are the chances this thing was at the bottom of a lake?
