Doolin
- May 22, 2009
- 67
Hi All,
I've been looking at a new anchor (don't currently have one for the new boat) and will be going with the Columbia River 'rocker' style.
Everywhere I've seen info on this type of anchor, they use the bouy with the puller 'lock' underneith. If you're not familiar with this type of setup there's a video of how they work here:
http://www.savvyboater.com/p-2116-anchor-lift-pro-heavy-duty-anchor-puller.aspx
It took a while for me to 'get' how the puller worked but it seems pretty cool now.
My remaining question is how are these used with multiple lines?
In researching the anchor, I found that the minimum 'line to depth' is 3-1 (i.e. 100' of water = 300' of line) to keep the anchor chain horizontal to absorb wave lift. I don't anticipate anchoring in more than 100' of water, usually way less... but figured I'd be prepared. So, If I've got 3 100' sections of anchor line (I don't want to have a single 300' line), how would you use the puller. It really doesn't look like a knot would pass through the puller lock.
