Re: Spring Maintenance List
Yes, they are the two bolts at the top of the gimbal ring. They are bolts with nuts, so you will have to get a box end wrench on the back side. These bolts clamp the gimbal ring to the steering pivot pin. If they loosen over the years, you can get side to side play in the steering, and it can wear out the ring.
Also the gimble ring swres. Will those be obvious as to what I am to retorque?
