jlinder
- Jul 5, 2004
- 1,086
Re: is 12 gauge wire fat enough for my trolling motor?
Regarding how the electrons actually flow - The electrons move from the negative to the positive terminal. If I remember correctly the reason we draw current as flowing from the positive to the negative (the other way) is due to Benjamin Franklin who defined it as such. He did not know about electrons at the time.
Someone asked about why we put the fuse in the positive. Cause that is what we do. We treat the negative as the common and fuse the positive. Back 50-60 years ago some cars were built with a positive ground - the reverse of what we do today. It does not matter, as long as you are consistent.
Of course, all this is great trivia but has no bearing on the questions at hand.
Regarding how current flows in wire that is doubled - it will flow based on the resistance, but you are talking about varying percentages. If you took one wire with one resistance, and another with double the resistance, the lower resistance wire would carry twice the current as the higher resistance wire.
It is not a winner take all situation.
In this case with the two wires being the same I doubt you could find test equipment that would be sensitive enough to be even able to measure the difference.
Doubling wires for house hold wiring is a little different and generally not done. One reason may be that is it alternating current. With AC you need to be concerned that the path lengths match or they would combine with different phase angles. Of course this would not happen unless you had some really different paths for the 2 wires but it is just not typically done.
Regarding how much current you can put through a wire there are 2 things to consider - will the wire heat up and how much power is lost in the wire.
For heating/safety think of this: In house wiring 12GA will carry 20 amps, 14GA will carry 15 amps, and every 4 gauge sizes will double or halve the capacity (e.g. - 10GA will carry twice what 14GA will, or 30 amps). Just a rule of thumb but not far off.
For power lost you are worried about voltage drop. The longer the wire the more the chance you will need to increase the wire size from that needed to prevent excessive heating. For that you can do a google search for voltage drop calculators, but if you only have a 4 ft run, or a total path of 8 ft. I don't think that will be a factor.
Someone mentioned looking at the fuse. The size has to be at or less than the current capacity of the weakest link in your circuit (wire, switches, motor, etc.). If you fuse is 40A then your wire must be rated to safely carry 40A.
Hope this helps
Hope this helps
