Hello everyone I have a 1971 115 hp mercury ob short shaft serial number 3037534 and I have a few questions. First of all I Just bought the boat this motor was on and it was not running it need a distributor so I installed a used one and did the link and sink got it running and changed the lu lube it was very milky. Then took it out on the water for the first time to see how it ran. I had no problems and it ran fine. So now I want to go though motor and make sure there are no problems that way it will be ready for this summer. So my questions are
1. The mercury switch on this motor was unhooked and I?m not sure why it is there and how necessary it is or what exactly it dose?
2. I have removed the power head and lu, and the exhaust tube pn 38469 is missing it looks like it directs exhaust in to the prop of the lu, I?m not sure how necessary this was and if I need to find a new one, or where to find a new one.
3. I would like any input on what parts to replace out of maintenance so that I will have no problems with this motor . I planed on so far New water pump, pressure checking the lu and fix any seal leaks found, replace distributor bearings they were a little ruff when I put the used one in, fix the motor mounts some of the bolts are loose. Replace all rubber balance and fuel line hoses. I also would like some input on replacing the case seals and crank seals if that is a good idea to do just to be on the safe side and maybe kit the carbs?
Thanks for any input.
